Is such a thing possible? It seems to keep the value it has at the Attach Frame.
Edit: Found this similar question:
https://www.sidefx.com/forum/topic/58607/ [www.sidefx.com]
Can't find a constraints property node though.
Edit 2 : Nevermind, was one level too high. Anybody wondering, this works if you create a group for your constraint and animate the value in a constraint property node, inside the Dopnet that's inside your SOP vellum solver.
Vellum / Attach to geometry - Animating the Stretch stiffness scale value.
3980 3 3- Tanto
- 367 posts
- 8449 posts
- Tanto
- 367 posts
- mackerBaehr
- 81 posts
Hello Tamte and Tanto.
Also I am looking for a way to animate stretch stiffness scale values, preferably through a keyframed re-ramp (something I would normally do in a pointVOP. When I insert a constraint property node though, it doesn't show the property ‘stretch stiffness’, as far as I can see. Let alone how I could use a re-ramp parameter. What would be the way to go?
