Hi
I am trying to find a method to calculate the difference in rotation/orientation between point A and B, and add that difference/offset to the existing orientation of point C.
What would be the most elegant way?
Michiel
how to calculate and apply orientation offset points
3128 8 2- mackerBaehr
- 81 posts
- toadstorm
- 359 posts
Assuming you have the orientations of your A and B points stored as quaternions or matrix3's, you can find the “difference” between them by inverting the orientation of A and multiplying it by the orientation of B. Then take that result and multiply it by the existing orientation of C.
// i might be getting the order of operations wrong here, might want to double check vector4 diff = qmultiply(qinvert(A), B); vector4 new_C = qmultiply(diff, C);
- mackerBaehr
- 81 posts
Thank you, Toadstorm, I will give that a spin. My nose was already pointing in that direction a bit but to find the proper means through trial and error requires quite some luck. Quaternion multiplication indeed sounds like the logical route. Didn't new matrices could also be qmultiplied.
Michiel
Michiel
- toadstorm
- 359 posts
Matrices can just be multiplied using * in VEX… there's no special function for it. Inverting a matrix or matrix3 is done with the invert() function instead of qinvert(). Otherwise the basic idea behind the code is the same.
Edited by toadstorm - Dec. 3, 2019 09:35:10
- mackerBaehr
- 81 posts
- Aizatulin
- 475 posts
another way to get a rotation matrix, which transform a point A to points B direction, is using the dihedral() function (which works for quaternions and matrices aswell).
The function takes two points as input and returns a rotation matrix as output, which rotates point A to B.
This function looks like, that it takes the cross product of A,B, which is defining an rotation axis (if A,B are not on a line) and the angle, whic can be calculated using the dot product.
Here is an example, where you can use point attributes as multiplier for the angle, which can set in a wrangle.
- mackerBaehr
- 81 posts
@Toadstorm: Are you sure matrices can be qmultiplied? Houdini gives me an error “Errors or warnings encountered during VEX compile:
No matching function for vector4 qmultiply(vector4; matrix3). Candidates are: vector4 qmultiply(vector4; vector4)”. This would in a certain way make sense to me (with my limited grasp of math), since I thought matrices were in the domain of linear algebra and quaternions in the non-linear domain..
@Aizatulin: Thanks for the example. It's a bit overwhelming, I can't yet discover if it would apply to my case. I am looking for a per point-comparison: ((diff orientation between P1 and P2) added to the existing rotation of P3). I do however understand that the dihedral function might apply here..
- toadstorm
- 359 posts
In the last post I said matrices can be multiplied using the * operator, and inverted using invert() instead of qinvert(). You can convert from a matrix3 to a quaternion using quaternion(myMatrix3) if you need to, or go the other way around using qconvert(myVector4).
- Aizatulin
- 475 posts
