I decided to post python viewer states problems in this thread.
In H17.5, after activation with onResume method, the state continues to generate the mouse move event (hou.uiEventReason.Located). But in H18 this type of event stops happening.
Test build: Houdini 18.0.318 Linux version
Python Viewer States Issues
2584 13 3- Alexey Vanzhula
- 538 posts
- Alexey Vanzhula
- 538 posts
I have solve the problem myself
Anyway, according to the documentation:
this value have to be True by default, but in fact it is not.
def onGenerate(self, kwargs): kwargs['state_flags']['mouse_drag'] = True
Mouse drag events are generated by default (True)
Edited by Alexey Vanzhula - Dec. 15, 2019 08:30:56
- Alexey Vanzhula
- 538 posts
- Alexey Vanzhula
- 538 posts
- Alexey Vanzhula
- 538 posts
Currently, we can't draw the drawable geometry immediately after activating the state in the onEnter or onGenerate methods. In the current Python states implementation, we must first move the mouse to update the drawables. So, we need a method to force update.
Edited by Alexey Vanzhula - Dec. 22, 2019 09:18:36
- Alexey Vanzhula
- 538 posts
- mabelzile
- 398 posts
vux
Ok thanks for reporting. It's best to log bugs though so python states issues don't fall in the cracks.
- mabelzile
- 398 posts
- mabelzile
- 398 posts
vux
Use `hou.GeometryViewport.draw()` to force a redraw.
- Alexey Vanzhula
- 538 posts
Thank you for answers!
Yes, but this did not work in my case. I will show my example in a few hours
mabelzilevux
- Alexey Vanzhula
- 538 posts
In this example, I want the circle to appear immediately after the state is activated. But it appears only after I start to manipulate the viewport using the Alt key.
class TestTemplate(object): _drawable_geo = hou.Geometry() circle = hou.sopNodeTypeCategory().nodeVerb("circle") circle.setParms({ "type": 2 }) circle.execute(_drawable_geo, []) del circle def __init__(self, scene_viewer, state_name): self.scene_viewer = scene_viewer self.state_name = state_name self._drawable = hou.SimpleDrawable(self.scene_viewer, self._drawable_geo, "test_drawable") def onGenerate(self, kwargs): self._drawable.enable(True) self._drawable.show(True) self.scene_viewer.curViewport().draw() # UNREGISTER if hou.ui.isRegisteredViewerState('test_state'): hou.ui.unregisterViewerState('test_state') # CREATE AND REGISTER template = hou.ViewerStateTemplate('test_state', 'Test State', hou.sopNodeTypeCategory()) template.bindFactory(TestTemplate) hou.ui.registerViewerState(template) # ACTIVATE scene_viewer = hou.ui.paneTabOfType(hou.paneTabType.SceneViewer) scene_viewer.setCurrentState("test_state")
- mabelzile
- 398 posts
It works fine in H18 with this python state file version:
Tools:
import hou import viewerstate.utils as su class State(object): _drawable_geo = hou.Geometry() circle = hou.sopNodeTypeCategory().nodeVerb("circle") circle.setParms({ "type": 2 }) circle.execute(_drawable_geo, []) del circle def __init__(self, scene_viewer, state_name): self.scene_viewer = scene_viewer self.state_name = state_name self._drawable = hou.SimpleDrawable(self.scene_viewer, self._drawable_geo, "test_drawable") def onGenerate(self, kwargs): self._drawable.enable(True) self._drawable.show(True) #self.scene_viewer.curViewport().draw() def createViewerStateTemplate(): """ Mandatory entry point to create and return the viewer state template to register. """ state_typename = "z" state_label = "Z" state_cat = hou.sopNodeTypeCategory() template = hou.ViewerStateTemplate(state_typename, state_label, state_cat) template.bindFactory(State) template.bindIcon("MISC_python") return template
Tools:
import stateutils as su viewer = su.findSceneViewer() viewer.setCurrentState("z")
Edited by mabelzile - Jan. 5, 2020 13:53:40
- Alexey Vanzhula
- 538 posts
mabelzile
It works fine in H18 with this python state file version:import hou import viewerstate.utils as su class State(object): _drawable_geo = hou.Geometry() circle = hou.sopNodeTypeCategory().nodeVerb("circle") circle.setParms({ "type": 2 }) circle.execute(_drawable_geo, []) del circle def __init__(self, scene_viewer, state_name): self.scene_viewer = scene_viewer self.state_name = state_name self._drawable = hou.SimpleDrawable(self.scene_viewer, self._drawable_geo, "test_drawable") def onGenerate(self, kwargs): self._drawable.enable(True) self._drawable.show(True) #self.scene_viewer.curViewport().draw() def createViewerStateTemplate(): """ Mandatory entry point to create and return the viewer state template to register. """ state_typename = "z" state_label = "Z" state_cat = hou.sopNodeTypeCategory() template = hou.ViewerStateTemplate(state_typename, state_label, state_cat) template.bindFactory(State) template.bindIcon("MISC_python") return template
Tools:import stateutils as su viewer = su.findSceneViewer() viewer.setCurrentState("z")
Houdini 18.0.340 Linux. The drawable appear only after moving the mouse. Test it from the Python Source Editor.
- Alexey Vanzhula
- 538 posts
