I have a problem with the rops. I have around 9 rops merged into one merge rop node to render multiple mattes.
I select the merge node and I hit Render and it starts rendering but for some reason it is always accumulating RAM from the frame before it and after 10 frames, the app ends up using around 100% memory and crashes.
I am having to restart Houdini every few (10-ish) frames for it to release the memory and continue rendering.
Anyone has a solution?
I even tried chaining the rop nodes in sequence and hitting render. It has the same effect.
Rop Merge Accumulating RAM memory = Crash
1047 6 0- eitch
- 36 posts
- Enivob
- 2535 posts
- eitch
- 36 posts
- eitch
- 36 posts
- eitch
- 36 posts
Seems like the “sopcache -c” HScript command (along with root user access) fixed the ram issue, but it kind of beats the purpose of reusing the loaded data for each rop since each rop will be rendering the same frame.
I guess I need to find a way to clear the sopcache only after all 9 rops are finished and it moves to the next frame.
- eitch
- 36 posts
So that did not work out at all
I'll just render it rop by rop. I have very little experience with the out context.
If anyone has an idea please let me know.
I found these threads to be helpful but nothing worked:
https://www.sidefx.com/forum/topic/21822/?page=1#post-101595 [www.sidefx.com]
https://www.sidefx.com/forum/topic/58756/ [www.sidefx.com]
https://forums.odforce.net/topic/33152-ram-cleanup/ [forums.odforce.net]
Edited by eitch - Feb. 4, 2020 14:44:08
- eitch
- 36 posts
