Hey all,
I'm trying to change the default path to the executable for the rizom bridge in the labs tool set. I have updated my houdini.env file with a line like this:
RIZOMLOC=“D:/Rizom Lab/RizomUV 2019/rizomuv.exe”
It doesn't seem to be affecting the Rizom nodes. I'd assumed the env is the right place to change this but perhaps no?
Many thanks,
Pete
Labs - Setting custom Rizom exe path?
3606 6 2- peternicolai
- 37 posts
- heimlich
- 14 posts
you can set the path in the settings for the node..
Oliver Hotz
#creator of ODShelfTools for Houdini: https://origamidigital.com/cart/index.php?route=product/category&path=59_63 [origamidigital.com]
- peternicolai
- 37 posts
- heimlich
- 14 posts
i believe thats how it currently is setup.. you could always save as default settings on the ndoe..
Oliver Hotz
- peternicolai
- 37 posts
yeah, from what I can see the paths look to be hard-coded and aren't pulling in any global var. I'll have to update each node with my new path and then redo that each time the tools get updated.
I guess longer term it would be cool if these nodes could follow a similar path to the gaea tools. Initially we had to provide a path to the exe but now I believe the location is gathered from the registry (?) which is pretty nice and invisible.
Anyway, I guess I have my answer for the time being.
Pete
Pete
- jomaro
- 85 posts
- oliver7
- 282 posts
its in the settings.. you can save a new permanent default after changing it
Edited by oliver7 - Nov. 29, 2021 19:23:47
Oliver Hotz
Origami Digital
Author of ODTools for Houdini: https://origamidigital.com/cart/index.php?route=product/product&path=59_63&product_id=66 [origamidigital.com]
Origami Digital
