I am experimenting with dynamics, making an object remain in place until another object collides with it and then it falls with gravity.
Is there a better way than connecting a Gravity node to the object to be temporarily static and keyframing its force from a positive Y value (to counteract another global Gravity node) to 0 at the frame of collision? In Maya you can activate the dynamics of objects on/off simply.
OK,Ive discovered the Active Value node. This lets you turn dynamics on/off on individual objects. Seems to be the method.
How to keep object stationary until collision?
3272 10 1- litote
- 224 posts
- vusta
- 555 posts
- litote
- 224 posts
- vusta
- 555 posts
litoteif you're using Apprentice…I don't see why you should be stuck on 17.5
Thanks but your scene file crashes my Houdini app (17.5).
What is your method, do you use an Active Value node?
c'moooooooooon get on 18 and get all the goodies !!!!
(it's ‘sleep’ property)ie. if nothing impacts you…you stay asleep forever.
- litote
- 224 posts
- vusta
- 555 posts
- litote
- 224 posts
- vusta
- 555 posts
c'mon, seriously…I've had to go back do it in 17.5 gave you a 17.5 file…like cmon.
https://www.sidefx.com/docs/houdini/nodes/sop/rbdconfigure.html [www.sidefx.com]
can you not simply get 18 Apprentice ? it's FREE.
- litote
- 224 posts
Thanks, much appreciated. I don't want to get the Apprentice version and I don't want to risk having problems with installation, as has happened before. For now I will stick to 17.5. But I am glad you showed me the RBD Configure SOP so I can study it. Sorry to take up more of your time. Don't know why your file crashes my version.
- vusta
- 555 posts
- litote
- 224 posts
