I'm trying to save data in UV but i can't do that
p@uv4=set(1,@uv4.y,@uv.z,@uv4.w); //this is not working
v@uv4=set(1,@uv4.y,@uv.z); //That's OK
Someone to help?
Vector4 UV is possible?
1718 4 1- pan
- 4 posts
- 8449 posts
- pan
- 4 posts
- 8449 posts
panthen it sounds like you already have v@uv4 attribute on the input geo instead of p@uv4
I'm not getting an error.
but when i'm select v4 attribute wrangle i can't see UV4 channel but v3 wrangle is OK.
just running p@uv4 = something on next wrangle would not cast uv4 from float3 fo float4, so make sure your input attribute is correct type
but if you don't see it at all, then maybe something else is going on, post a file
EDIT: aaah, you don't see it in that list, not in geometry spreadsheet
for those you need to set attribute type info to texturecoords
setattribtypeinfo(0, "point", "uv4", "texturecoord");
but it will at least show up in texture related sops like uvtransform if you set the type info
Edited by tamte - April 5, 2020 12:35:40
- pan
- 4 posts
