Is there really no way to rename an attribute in TOPs?
I need to compare values on two array attribs but can't get them to the same work item as they share the same name.
Attribute rename?
1504 3 2- kahuna031
- 897 posts
- chrisgreb
- 603 posts
- kahuna031
- 897 posts
- chrisgreb
- 603 posts
Yes, sorry we have an outstanding RFE to improve our array attrib handling. In the meantime you'd have to use a python processor with the following `onGenerate` Callback (assuming your array attrib is called ‘ia’):
# Clone Upstream Items for upstream_item in upstream_items: # This clones all data, output results and keeps the same work item # type as in the upstream item work_item = item_holder.addWorkItem(cloneResultData=True, preserveType=True, parent=upstream_item) work_item.setIntAttrib('ia_copy', work_item.intAttribArray('ia')) work_item.eraseAttrib('ia')
