Hi all,
I don’t quite understand the meaning of deactivating prims if then nothing can be put inside the hierarchy. I took an example of a scene from the Market Scene archive. In this scene, we first deactivate the light sources, and then try to add as part of the layer, but this fails. What could be the mistake?
Prune Deactivate
4794 10 2- alexwheezy
- 196 posts
- mtucker
- 4435 posts
As is often the case, the USD Glossary provides a good (if dense) description of prim deactivation: https://graphics.pixar.com/usd/docs/USD-Glossary.html#USDGlossary-Active/Inactive [graphics.pixar.com]
Because USD doesn't compose (or really even look) inside deactivated prims, it also can't add or edit prims inside a deactivated branch. Deactivating a branch provides a performance advantage over simply making a branch invisible, with the downside that the deactivated portion of your scene graph becomes “off limits”.
- alexwheezy
- 196 posts
mtucker
I was confused not by the very term deactivation in the context of USD, but by the fact that in the initial lessons and examples of scenes from SideFX that the authors did the same as in the screenshot above. Some data is deactivated, and then they try to add something there, but this fails.
If in the example of the scene there was an idea to show that after deactivation this hierarchy branch becomes inaccessible to us, then yes I understood the lesson.
- mtucker
- 4435 posts
- 7733 posts
I think the scene in question is the “MultiShotWorkflowDEMO”, which was created in a pre-release version of Houdini 18. There are a number of load warnings due to parameter interface changes.
The source of the problem seems to be the addition of the “Prune Ancestors Automatically” option, which is enabled by default, and most likely didn't exist at the time the scene was created. Disabling this option prevents the ancestor prims including ‘/lights’ from being pruned, since they are reused later on. Perhaps editproperties nodes in ‘create mode’, such as a light lop, could automatically ‘un-prune’ the ancestors of the prims they are creating?
- alexwheezy
- 196 posts
Yes, there is a reference to this example, and there is a discussion in the LOPS tutorial 4 Layout Department: Shot Layout
In shot_004, we have grabbed the lighting from shot_001 with a Prune LOP (to remove the camera but keep the lights) and a Merge LOP, (to layer the lights into the scene).
Prune LOP:
Primitive pattern
/ Scene / Cameras / Shot * (removes all cameras begining with “shot”)
Method
Deactivate
Merge LOP:
Merge style
Flatten Into First Input Layer
Prune LOP:
Primitive pattern
Method
Deactivate
Merge LOP:
Merge style
- mtucker
- 4435 posts
Thanks @alexwheezy.
I'm pretty sure @jsmack is right, that this problem was introduced by that “automatically prune ancestors” option on the prune, which was added after the 18.0 release.
As to the suggestion of auto-unpruning, that's a very dangerous game. Either you unprune all the ancestors of the prim you are about to create (in which case you risk loading in a dangerously large amount of scene graph), or you unprune your direct ancestors, but prune siblings instead so that only the minimal set of stuff gets activated. But in that case, re-activating things becomes a _lot_ more complicated.
- 7733 posts
mtucker
This is kind of what I was thinking, but you have a good point. Is there a node warning when attempting to author a prim with pruned ancestors?
Edit: The screenshot shows a warning, but it's not very helpful.
Edited by jsmack - July 12, 2020 00:56:21
- Galleryworm
- 21 posts
Hi, I think I'm running into a situation sort of related to this post. I've authored a base layer of USD with scratch lights, render settings, and cameras. I'm sublayering this file into a fresh lops graph and I'd like to prune out the existing lights and build a new lighting setup, but I'm unable to get rid of the old lights in the scene graph tree without pruning the individual light's ancestor prim ("/lights/") This, of course, makes them disappear in the tree view, but when I drop in a new light, it throws an error regarding the ancestor prim.
The only thing that seems to work is to prune out the lights individually by using a wildcard ( /lights/* ) This is all fine and dandy except all of the old lights still show up in the scene graph tree view. Is it possible to prune out lights without having them show up in the scene graph tree without completely pruning out the ancestor prim and causing the ancestor prim-related error?
Edited by Galleryworm - Feb. 20, 2021 01:55:20
- mtucker
- 4435 posts
- Galleryworm
- 21 posts
