@Soothsayer
Do you mean Light samples mode to uniform and convergence mode to path traced? Best Mark
Is there any reason to switch to Karma? Is unbelievably slow
33740 64 9- Mark Wallman
- 644 posts
- Soothsayer
- 858 posts
Mark Wallman
@Soothsayer
No, the variance one below. The idea is to find out what max pixesamples we need to use without interference from other optimizations.
That makes me think, we change variance according to image planes but I wonder if components (diffuse, refl) would be useful too? Just thinking out aloud in case sesi listens in. I really think optimizing those pixel samples is key and the more tools we get to modify or inspect this the better. Otherwise karma just keeps shooting rays at irrelevant parts of the image and we'll never know.
Edit: Actually I saw that just today they changed the pixel sample default from 128 to 9. That's much more in line with other renderers. Not that it changes karma's inherent speed much but at least newcomers aren't hit with this huge shock.
Edited by Soothsayer - Nov. 3, 2020 07:14:31
Jobless
Jobless
- aghiles
- 13 posts
Daryl Dunlap
Buying 3Delight makes no sense, SideFX already has a production CPU engine in Mantra - and SideFX clearly accepts that CPU engines are a legacy product - as SideFX has literally stated, they are not investing in their Mantra codebase anymore.
You don't even have to buy it: first license is free for commercial use And you get 1000 mins of free cloud rendering.
… GPU is the future and AI has just begun its disruption in the 3D/VFX industry.
No one can really predict the futur but I don't see any disruption coming from AI and GPU on the production side of things in the medium term at least.
//AK
The 3Delight Team
The 3Delight Team
- EdganHomt
- 13 posts
aghilesDaryl Dunlap
You don't even have to buy it: first license is free for commercial use And you get 1000 mins of free cloud rendering.… GPU is the future and AI has just begun its disruption in the 3D/VFX industry.
It's already starting, in the next 5 years we'll be surrounded by AI tools in 3D productions. One example: https://graphics.pixar.com/library/SuperResolution/ [graphics.pixar.com]
- TwinSnakes007
- 603 posts
aghiles
Edited by TwinSnakes007 - Nov. 12, 2020 10:06:41
Houdini Indie
Karma/Redshift 3D
Karma/Redshift 3D
- lewis_T
- 236 posts
What is your point? I see a great example, but using hard surfaces, approximate motion blur (that looks odd) and playing to
the strengths of the GPU. I'm not sure why you are so against CPU offline rendering. Have you worked in Studios that are
able to push heavy production scenes through a GPU? Because I haven't seen one example of this. I'm for both CPU and GPU,
but there is no way offline CPU is going anywhere. Not with the data sets we have to munch.
I did see Moana pushed through a GPU, at 5hrs for a frame, at 1k. Though that might have been a more academic exercise
so not sure if it's accurate. I tried to find a RS or Octane, etc example of the Moana set being rendered, but couldn't see
anything. Do you have some heavy data set examples?
There is room and scope for both GPU and CPU.
L
L
- pbdj
- 44 posts
- Mark Wallman
- 644 posts
Hi.
So I am testing a range of renderers in Solaris.
For Karma however there are a few things that are helping me.
-add a lightmixer just before your render, add all lights into a collection and increase the expose up by 10.
-in the Karma HDA LOP, go into the color limit and increase it to stop high value pixels clamping (for me my current limit is 10000 rather than the default 10).
-In nuke/fusion etc take down the exposure of your render by the same number of stops that you increased it by.
This is getting rid of a lot of grain. I use this principle in a lot of render engines.
I am still doing a bunch of testing with different render options. If I find anything usfull I will post up.
Best
Best
- TwinSnakes007
- 603 posts
- lewis_T
- 236 posts
- TwinSnakes007
- 603 posts
A slight tangent to the topic, but, relevant none the less.
https://www.sidefx.com/community/epic-games-invests-in-sidefx/ [www.sidefx.com]
LiveLink from Houdini is gonna be even better. I'd imagine Studios adjusting Sets in real-time and seeing those results on those LED stages in real-time as well.
Houdini Indie
Karma/Redshift 3D
Karma/Redshift 3D
- TwinSnakes007
- 603 posts
- Midphase
- 833 posts
It's an interesting development. My guess is that Epic actually tried to buy SideFX outright, and ultimately SideFX didn't want to sell and this is the best they would both agree to. If SideFX was a publicly traded company, I think it would have been a very different story.
>>Kays
- TwinSnakes007
- 603 posts
Yup, I was saying the same, Epic definitely has the cash, and some folks said Kim said he'd never sell.
Christopher just posted on FB, that nothing “really” will change because of this investment. But, one can dream of tighter integrations.
Edited by TwinSnakes007 - Nov. 13, 2020 18:08:14
Houdini Indie
Karma/Redshift 3D
Karma/Redshift 3D
- Heileif
- 125 posts
tinyhawkus
L
The Moana scene have been converted to Redshift. Info about it here https://www.redshift3d.com/forums/viewthread/32082/ [www.redshift3d.com]
Here is the rendertime from the post. “The above took about 46 minutes to render at 2048x857 on a single RTX 8000.”
But you should read the forum post, and you will know some of the problems with getting the render running, interesting stuff
Edited by Heileif - Nov. 13, 2020 21:12:06
- lewis_T
- 236 posts
That Article is indeed interesting. And proof about the pitfalls of GPU rendering. There is room for both as I've said
several times, this illustrates the point. An AMD 3950x was able to render Moana in 13 mins at 4k, using about 46gb
of ram. With all SubD and displacement enabled.
- TwinSnakes007
- 603 posts
….and go!
80.lv: Gods of Mars Will Be Shot Entirely In Unreal Engine.
https://80.lv/articles/gods-of-mars-will-be-shot-entirely-in-unreal-engine/ [80.lv]
TLDR;
Gods of Mars is the first Hollywood production to use real-time rendering of game engine animation/images as finished Final Pixel shots. This is done by our cross-medium creative team that merges game programmers with traditional matte painters and miniature makers with Hollywood pedigrees. To push Unreal Engine to meet the high-quality standards equal to current VFX/animation software
TLDR;
Edited by TwinSnakes007 - Nov. 19, 2020 22:31:03
Houdini Indie
Karma/Redshift 3D
Karma/Redshift 3D
- BrianHanke
- 433 posts
Daryl Dunlap
I'm interested to see how this develops. My main issue with Unreal/Unity filmmaking is that characters tend to look really jank compared to traditional CGI. Real time is great for hard surface and environments, but I've never seen convincing humans or animals. I'm thinking of Oats Studios ADAM (Unity) and the tech demo trailers that Unreal and Unity put out every once in a while. It's just not there yet. Not sure if it's a matter of having the right team of genius artists come along to make it work, or if the tech still needs a few years to mature…
- TwinSnakes007
- 603 posts
Me too Brian. I'm excited what the platform (GPU) represents. Its like a feeding frenzy among IP creatives, everyone is creating these…pieces of functionality…and the synergies are like..exponential between them, inherently.
You create an asset and then, there's this entire ecosystem that pushes that asset to its Final form in record time.
What AI is doing with inference is sobering as well.
Houdini Indie
Karma/Redshift 3D
Karma/Redshift 3D
- Marco Dörner
- 31 posts
Daryl Dunlap
….and go!
TLDR;
This reminds me a little bit of when they shot some episodes (or entire seasons) of shows on an iPhone. More to make the point “yes, it can be done” than because it's better (in quality, in way of working for the crew, the DI, the …). Also it will probably - as you said - push the engine forward. But I think if you just asked an unbiased filmmaker, who just wants to produce the best stuff, with the least problems they would go for a “real” camera every day (or established offline rendering workflows in this case - not for previz, but for final image. Virtual production is another beast here because it's new, there is nothing established yet).
