Hi all,
Houdini crashes for me really often when using on screen handles. If I open a scene add a box and edit the bevel it will immediately crash. This also happens with a lot of the other SOP nodes. Poly extrude is a bad one, even snap will crash half the time. Then I open it back up and it’ll work. I’m just finding that I’m having to restart continuously throughout modelling session and it’s really slowing me down
Just wondering if anyone else gets this? I’m on Big Sur now but it was just as bad in the Catalina.
Pete
Crashes when using in screen handles. OSX
1706 7 2- peteski
- 517 posts
- edward
- 7715 posts
- peteski
- 517 posts
- edward
- 7715 posts
- Midphase
- 833 posts
What version are you using?
>>Kays
- peteski
- 517 posts
- peteski
- 517 posts
- Midphase
- 833 posts
You need to provide the actual build version if you're expecting real help. More specific details the better, including OS version, system specs, etc. and ideally a .hip file that is crashing for you so that I can launch it on my machine and confirm that the issue persists or if it's isolated to your computer.
Otherwise you're just posting the equivalent of “My car crashes whenever I turn right” which is not particularly helpful for us to help you with.
Also, to answer your question in the original post – No, I'm not running into any crashes as you describe. Everything works as expected. I'm running the latest Catalina and Houdini 18.5.393 at the moment (because the 18.5 Production build is garbage).
>>Kays
