Vertex Wrangle ad-hoc group doesn't work?
1861 4 0- probiner
- 339 posts
- 7759 posts
- probiner
- 339 posts
jsmackAppreciate the suggestion, @jsmack, helps to create a better report. Unfortunately setting the group to be explicitly of Vertices doesn't work as seen in the image. @foo is not even created.
Group type "guess from group" only works for explicit groups, or it assumes a point group for ad-hoc groups on wrangles.
Explicitly select 'vertex group' and it should work.
RFE filed.
Edited by probiner - Dec. 21, 2020 11:10:36
- Herve
- 40 posts
- probiner
- 339 posts
Herve
on top of what jsmack said...
you're maybe missing an equal sign, in your Group param'? :
it should be @bar==1, not @bar=1
The syntax for @atribute=value is with a single equal sign:
I did try == just to check and all the outputs from points, prims, vertices are the same.
Edited by probiner - Dec. 26, 2020 07:30:24
