Using the generateIFD/Render IFD combo, I notice that the default Output Path on the Render IFD TOP has a default value.
Which, if I understand correctly, means that will _always_ override the output path specified in the Generate IFD TOP.
If I'm correct, I would strongly recommend removing the default value in the Render IFD TOP's Output Path field, currently it's very confusing. IMO of course.
peter B
Q/Confusing default - Render IFD
1980 6 2- pbowmar
- 7025 posts
- chrisgreb
- 603 posts
- pbowmar
- 7025 posts
Thanks Chris, though I'm a little confused by your comment that "you will not get an expected output" since I expect the output to be whatever I set on the Generate IFD TOP. Or am I misunderstanding?
If you mean the default value of $HIPFILE/etc/etc that's the same on Generate IFD TOP and the Render IFD TOp anyway, right?
Peter B
Peter B
- chrisgreb
- 603 posts
- pbowmar
- 7025 posts
- chrisgreb
- 603 posts
- pbowmar
- 7025 posts
