Hey!
Recently came across the Lentil Plugin which works great to keep render times down when using heavy DOF. As it's a camera shader it doesn't particularly like keyframed parameters, but I'd like to animated the focal distance.
Tried promoting the parameter and channel referencing but still not a fan - help would be much appreciated!
Error
Command Exit Code: -1073741819
00:00:00 76MB | Received: AA: 6 6
00:00:00 76MB | Received: begin
00:00:00 76MB | Batch mode
00:00:00 76MB | log started Fri Jul 23 18:44:54 2021
00:00:00 76MB | Arnold 6.2.0.1 windows clang-10.0.1 oiio-2.2.1 osl-1.11.6 vdb-7.1.1 clm-2.0.0.235 rlm-12.4.2 optix-6.6.0 2021/02/09 10:40:42
00:00:00 76MB | running on DESKTOP-OAMG1H2, pid=14888
00:00:00 76MB | 1 x AMD Ryzen Threadripper 2950X 16-Core Processor (16 cores, 32 logical) with 65432MB
00:00:00 76MB | NVIDIA driver version 460.89 (Optix 60800)
00:00:00 76MB | GPU 0: GeForce RTX 2060 @ 1830MHz (compute 7.5) with 6144MB (3766MB available) (NVLink:0)
00:00:00 76MB | Windows 10 (version 10.0, build 19042)
00:00:00 76MB | soft limit for open files raised from 512 to 2048
00:00:00 76MB |
00:00:00 76MB | Start
00:00:00 76MB | Received: log_verbosity: 7942
00:00:00 76MB | Received: log_console_enable: 1
00:00:03 362MB WARNING | /out/Beauty_Close_Skull:catrom_filter: could not read POINTER parameter "input"
00:00:03 362MB ERROR | Couldn't find imager input. Is your imager connected?
00:00:05 1309MB WARNING | output redefines AOV "Z" as type "RGB": ignoring and using previous type "FLOAT"
00:00:28 4950MB ERROR | signal caught: error C0000005 -- access violation
* Arnold 6.2.0.1 windows clang-10.0.1 oiio-2.2.1 osl-1.11.6 vdb-7.1.1 clm-2.0.0.235 rlm-12.4.2 optix-6.6.0 2021/02/09 10:40:42
* CRASHED in NodeLoader at 00:00:00
* signal caught: error C0000005 -- access violation
* backtrace:
>> 0 0x00007ff8d24293b0 NodeLoader
* 1 0x00007ff899c6cc1b Ordinal0
* 2 0x00007ff899ee1dc1
* 3 0x00007ff89a05d84d
* 4 0x00007ff949d61bb2 configthreadlocale
* 5 0x00007ff94b3b7034 BaseThreadInitThunk
* 6 0x00007ff94be22651 RtlUserThreadStart
* loaded modules:
* 0x00007ff8d2110000 lentil
* 0x00007ff899750000 ai
* 0x00007ff949d40000 ucrtbase
* 0x00007ff94b3a0000 KERNEL32
* 0x00007ff94bdd0000 ntdll
00:00:28 4952MB ERROR | signal caught: error C0000005 -- access violation
<quitting arnold from inside signal handler>
HtoA - Lentil Plug In
1541 1 1- RaveDonkey
- 3 posts
- mike.battcock
- 22 posts
