"ERROR:__main__:Could not determine port from connection file C:/Users/jdbgr/AppData/Local/Temp/houdini_temp/nukepipeline/pdgtemp/nukeserver_begin2_22_connection.txt"
(and I've also manually entered a port in the in the start server node)
Then after some dumpster diving in the logs I find this:
"Starting Nuke with RPC Server at 127.0.0.1:0
File "C:/Users/jdbgr/AppData/Local/Temp/houdini_temp/nukepipeline/pdgtemp/scripts/nukerpc.py", line 67, in <module>
exit_code = main(start_nuke_server)
File "C:\Users\jdbgr\AppData\Local\Temp\houdini_temp\nukepipeline\pdgtemp\scripts\genericrpc.py", line 384, in main
return start_server(args.host, server_port, extra, **kwargs)
File "C:/Users/jdbgr/AppData/Local/Temp/houdini_temp/nukepipeline/pdgtemp/scripts/nukerpc.py", line 54, in start_nuke_server
import nuke
File "C:\Program Files\Nuke13.0v2\lib\site-packages\nuke.py", line 7, in <module>
import _nuke
ImportError: DLL load failed: The specified module could not be found.
I've checked and sys.path looks fine, so that's not some wonky env situation. And it is actually finding the "nuke" module, but not the "_nuke" that is imported from within that module. And there is a _nuke.pyd which I've copied to _nuke.dll as a long shot, that didn't work. Also placed them in system32 as an ever longer shot.. no luck either.
Any clues? (houdini 18.5.532 Py3, win10, nuke 13.0v2)
