Group non straight curves
   869   2   0
I have several curves made up of sub curves that change direction.
I would like to know what is the best way to select the parts that change angle in order to eliminate them.
I have tried with the measure SOP but I have not known how to solve the problem.
Thanks in advance
if you want to group straight/non straight curves you can use the measure SOP (with curvature) and just accumulate the (abs value of the)curvature attribute. If the sum is small, the curve should be straight.
group_straight.hipnc (108.2 KB)
Hi Aizatulin,
Thank you for the quick response, it's exactly what I needed!
Bests,
