How to export groom attributes to Unreal?
   5336   5   1
Hello everyone!
Does anybody know how to export these two attribute with guides,when you export groom to Unreal?
  1. groom_closest_guides
  2. groom_guide_weights
I know it's not necessary, but I'd like to know how to make it work.
edit:
I guess groom_closest_guides = Influence Radius, groom_guide_weights = Influence Decay.
am I right?
Edited by Under_Pressure - Jan. 20, 2022 02:04:18
I also tried to export groom attribute 'uv'('groom_root_uv' in unreal) through + or as different combinations to unreal.
it's not working at all.
Under_Pressure
Have you tried Labs Unreal Groom Export SOP? It's new. Came out last week.
Mai Ao
Senior Technical Lead of SideFX Labs
youtube.com/@notverydarkmagic
MaiAo
is there a reference file for this? I tried exporting with the unreal groom for UE5preview1 but I have to reimport and translate before exporting another ABC to make it import aligned correctly to the fbx in UE5. If I try to use UE5's import rotation it doesn't update, and if I use the translation in the UEgroom export, it looks like it's not rotating correctly. I'm also not sure how to properly pipe in the groom from the guides. I can get it in and match the fbx 1:1 if all the hair is guides though.
houdini 19.0.547
with labs 19.0.531
Edited by Sirvoxelot - March 4, 2022 01:22:12
Pig groom to UE5.hiplc (896.8 KB)
oh nevermind,maybe it was an update, but now when i export the groom into UE, it seems like it imports fine with guides and strands, but it seems like the strands actually shifts position a bit
Hello guys! Please can you help with attribute groom_closest_guides, groom_guide_weights? How correctly export this attribute into Unreal (*.abc)?
