Click each shelf button? You mean some customized shelf buttons, or each and every shelf buttons?
I unzipped the folders "packages" and "viewhistory" inside the folder : Documents\..\Sidefx\houdini19.0 , is this correct?
Do I still have to edit the file 456.py as you shown?
David
Undo for viewport navigation ?
16682 25 5- Grendizer
- 375 posts
- animatrix_
- 4512 posts
I mean for the shelf tools provided inside the zip, there are 2 tools/buttons.
Yes correct. For 456.py if you have one, AFAIK one overrides the other, so you can merge the one in the zip with yours.
Grendizer
- Grendizer
- 375 posts
- animatrix_
- 4512 posts
Grendizer
thanks! I got it to work! Great job
There was a houdini bug about ortho view restoring that's fixed now so expect to download the latest houdini build to use that properly.
- Grendizer
- 375 posts
- animatrix_
- 4512 posts
If the hotkey issue is identified and fixed, I might update the script to process the hotkeys internally. I am using Shift+Z/A but it can be changed to anything easily, especially since it won't compete with other hotkeys when it's restricted to the scene viewer.
