I notice that if you have karma running in the viewport and disconnect stuff inside the shader the render view does not update automatically like it used to, I have now to restart the render manually.
Is there any settings that I am missing or is this a new behavior?
Solaris update render issue
979 2 2- mzigaib
- 944 posts
- robp_sidefx
- 446 posts
- mzigaib
- 944 posts
robp_sidefxFunny thing!
Can you provide a sample scene and let us know which build you're seeing this with?
I was just preparing a file to send you and suddenly for some reason the behavior changed and now it started to update again which is great and embarrassing because I am going to have to apologize to you guys and also thank you for the feedback.
Just to be more descriptive of my issue I was using:
-Fedora 36 - Nvidia proprietary drivers
-I used builds: 595 and 621 and both were showing the same behavior of not updating.
Maybe the fix had something to do with the opening a new linux shell and start a new Houdini? Idk but it is working now.
I'll keep a look in the behavior and let you guys know if something change.
Thanks again!
Edited by mzigaib - May 23, 2022 11:05:34
