Good day
Anybody have experience with how to instance volume with time offset ?
Retime instance LOP unfortunately doesn't work properly
Volume instance with time offset
1748 4 1- oslo
- 20 posts
- mtucker
- 4438 posts
- oslo
- 20 posts
- mtucker
- 4438 posts
In order to be able to retime your references, you need to cache the SOP Import so that all the volume data is available on the stage at the same time. Retime Instances isn't a TimeShift LOP - it doesn't recook its inputs, it just adjusts USD parameters, which means all the data needs to be on the stage at the same time.
Second, you had the Retime Instances node set to Point Instancer mode. But then you told it to retime individual references. So you should have had it in Native Instance mode. It should probably have been triggering an error in this case.
Finally, Retime Instances only seems to work if the prims you point it at are marked as instanceable. I have no idea why this would be the case, and I'd call this a bug, but at the moment it seems to be true. So you need to change the Instancer to create Instanceable References, not simple References.
Attached is a functioning version of the file. Updated to also have a frameoffset primvar, to demonstrate that the offset can be made different per-volume.
- oslo
- 20 posts
