I'm new to Linux. I got houdini working, so thank god for that.
On Side Effects installation FAQ it says to
“You will need to source houdini_setup in each shell that you run Houdini. You can add the following code to your .login file to automatically do this
pushd /opt/hfs8.2.13 <- use the build version that has been installed
popd”
where is this login file located or do i need to create it. thanks in advanced
Linux .login file question
4087 3 1- jerwhitehurst
- 9 posts
- Pagefan
- 519 posts
- pbowmar
- 7024 posts
- jerwhitehurst
- 9 posts
