Auto select node when checking display flag
2497 9 2- LukeP
- 232 posts
- CYTE
- 669 posts
Hey LukeP,
I only have this snippet to set the display flag on the selected node. so you can put that to a shortcut.
But I barely use it as I work with this all the time: Hotkey System [animatrixx.gumroad.com]
It's money well spent. As it will speed up your Houdini workflow a lot. It provides a function to select and display the node that is nearest to the mouse. so you don't even have to be over the node, just near it.
CYTE
# put all currently selected nodes in a tuple allnodes = hou.selectedNodes() if len(allnodes) == 0: hou.ui.displayMessage('Please select Nodes') else: #find last node Position of selected nodes lastNodePosition = len(allnodes)-1 # select last node lastnode = allnodes[lastNodePosition] # set display/render/selection flag on node lastnode.setDisplayFlag (True) lastnode.setRenderFlag (True) lastnode.setSelected(1,1)
CYTE
- eikonoklastes
- 330 posts
LukePIt doubles the number of clicks only when you want to do this. It's quite common to want to set the display flag to some other node, but continue working on the selected node.
Is there a way to auto select the node that I'm turning the display flag on? Seems like not being able to do so doubles the number of clicks one has to do...
As a workaround, you can click to select the node (or drag around it if you don't want to be precise), and hit R to display it.
- LukeP
- 232 posts
CYTE
Hey LukeP,
I only have this snippet to set the display flag on the selected node. so you can put that to a shortcut.# put all currently selected nodes in a tuple allnodes = hou.selectedNodes() if len(allnodes) == 0: hou.ui.displayMessage('Please select Nodes') else: #find last node Position of selected nodes lastNodePosition = len(allnodes)-1 # select last node lastnode = allnodes[lastNodePosition] # set display/render/selection flag on node lastnode.setDisplayFlag (True) lastnode.setRenderFlag (True) lastnode.setSelected(1,1)
CYTE
Thank you. Where would I out this snipped of code?
- animatrix_
- 4460 posts
LukePCYTE
Hey LukeP,
CYTE
Drag the code onto a shelf and then right click -> Edit Tool -> Hotkeys tab to assign a hotkey.
- 8449 posts
- CYTE
- 669 posts
tamteCYTEwhy?
isn't that what R is doing by default?
It also sets the display flag on the selected node while the mouse is over the viewport. that can be handy in some situations.
I use it mostly when I traverse the network via the Move to Previous/Next Operation commands, while the mouse is in the viewport.
CYTE
- pezetko
- 387 posts
You can add this code to
This will auto-select a node with the display flag set (and auto-deselect nodes without it):
This is just quick Proof of Concept (not production tested).
"$HOUDINI_USER_PREF_DIR/houdini19.5/scripts/OnCreated.py"
file. (Create the scripts folder and this file if it doesn't exist.)import hou def auto_select_on_display_flag_set(node, event_type, **kwargs): # pylint: disable=W0613 node.setSelected(node.isDisplayFlagSet()) def add_callback(kwargs): node = kwargs["node"] node.addEventCallback((hou.nodeEventType.FlagChanged,), auto_select_on_display_flag_set) add_callback(kwargs) # pylint: disable=E0602
- raincole
- 422 posts
- eikonoklastes
- 330 posts
raincole
Or when there are 3 manual steps but you do them thousands times? What's your point...?
A bit of a straw man here. The scenario being discussed is two manual steps, not three, and both steps are very comfortably in the natural resting positions for either hand.
You have to click on the node, so do that with the mouse, and then just hit R with your other hand.
You don't even need a precision click, because you can drag a rectangle over the node.
I'm huge on automating a grind, and use macros heavily, but this one seems entirely unnecessary to me. Still, I'm glad that there does exist a solution for those looking to minmax their lives.
Edited by eikonoklastes - Oct. 1, 2022 16:22:56
