Does anybody have any info how to use the Wedge Rop.
I have 8 diifrent fluid sims that needs to be manually output to file with different settings. The wedge Rop is suppose to do that but I can't use the $WEDGE, it's not recognized and so it wont write out something to disk.
Somebody how tried it
Jens
Wedge ROP
6157 6 1- jens_martensson
- 341 posts
- old_school
- 2540 posts
There are two ways to use wedging: random samples or iterating over a min and max value by a number of iterations.
I have yet to use the first method which is the default (I guess I wedge random seeds more than values themselves…).
I have attached a hip file that shows you how to set this up to wedge through a range of seed values. Don't forget to press the render on the wedge in to a local “geo” directory to the hip file.
-jeff
-jeff
- johner
- 809 posts
Hmm, trying this in ApprenticeHD, the Shell ROP inside the Wedge HDA errors out with “Operator unavailable in Non-Commerical Edition”.
Looking at the journals, that was supposed to have been fixed in 9.5.141, but it's not working for me in 9.5.163. If I just put down an empty Shell ROP and hit Render I get the same error.
- old_school
- 2540 posts
- jens_martensson
- 341 posts
- rdg
- 401 posts
- rdg
- 401 posts
