I know, I know… There is already answer “Do not use on board Intel video cards with Houdini” and I can agree with it but there are some cases when you just have no choice
I was able to run Houdini on my netbook with Kubuntu 8.04. It was working pretty well (not the most stable and fast solution ever but it was okay for some simple tests). Unfortunately it doesn't work in Kubuntu 8.10. I'm not sure which version of X.org / drivers exactly I had before but now what I see is just such message:
ERROR: could not obtain GLX visual!
Most likely cause is a lack of 3D acceleration. Check your configuration.
That's all good but as I understand everything is “fine” regarding to DRI.
glxinfo gives this information:
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_swap_control, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_visual_select_group
client glx vendor string: SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_allocate_memory,
GLX_MESA_copy_sub_buffer, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap
GLX version: 1.2
GLX extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_swap_control,
GLX_MESA_swap_frame_usage, GLX_OML_swap_method, GLX_SGI_swap_control,
GLX_SGI_video_sync, GLX_SGIS_multisample, GLX_SGIX_fbconfig,
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI Intel(R) 945GME 20061102 x86/MMX/SSE2
OpenGL version string: 1.4 Mesa 7.2
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_fragment_program, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_point_parameters, GL_ARB_shadow,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_crossbar,
GL_ARB_texture_env_dot3, GL_ARB_texture_mirrored_repeat,
GL_ARB_texture_non_power_of_two, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_window_pos, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_equation_separate,
GL_EXT_blend_func_separate, GL_EXT_blend_logic_op, GL_EXT_blend_minmax,
GL_EXT_blend_subtract, GL_EXT_clip_volume_hint, GL_EXT_cull_vertex,
GL_EXT_compiled_vertex_array, GL_EXT_copy_texture,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_packed_depth_stencil, GL_EXT_packed_pixels,
GL_EXT_point_parameters, GL_EXT_polygon_offset, GL_EXT_rescale_normal,
GL_EXT_secondary_color, GL_EXT_separate_specular_color,
GL_EXT_shadow_funcs, GL_EXT_stencil_wrap, GL_EXT_subtexture,
GL_EXT_texture, GL_EXT_texture3D, GL_EXT_texture_edge_clamp,
GL_EXT_texture_env_add, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod_bias, GL_EXT_texture_object, GL_EXT_texture_rectangle,
GL_EXT_vertex_array, GL_3DFX_texture_compression_FXT1,
GL_APPLE_client_storage, GL_APPLE_packed_pixels,
GL_ATI_blend_equation_separate, GL_ATI_separate_stencil,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_INGR_blend_func_separate, GL_MESA_pack_invert, GL_MESA_ycbcr_texture,
GL_MESA_window_pos, GL_NV_blend_square, GL_NV_light_max_exponent,
GL_NV_point_sprite, GL_NV_texture_rectangle, GL_NV_texgen_reflection,
GL_NV_vertex_program, GL_NV_vertex_program1_1, GL_OES_read_format,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_SGIX_depth_texture,
GL_SUN_multi_draw_arrays
3 GLX Visuals
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 24 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x22 24 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x54 32 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
36 GLXFBConfigs:
0x55 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x56 0 tc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x57 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x58 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x59 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x5a 0 tc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x5b 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x5c 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x5d 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x5e 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x5f 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x60 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x61 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x62 0 tc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x63 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x64 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x65 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x66 0 tc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x67 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x68 0 dc 0 32 0 r . . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x69 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x6a 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x6b 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 0 0 0 0 0 0 None
0x6c 0 dc 0 32 0 r y . 8 8 8 8 0 0 0 16 16 16 16 0 0 Slow
0x6d 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x6e 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x6f 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x70 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x71 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x72 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x73 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x74 0 dc 0 32 0 r . . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x75 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x76 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
0x77 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 0 0 0 0 0 0 None
0x78 0 dc 0 32 0 r y . 8 8 8 8 0 24 8 16 16 16 16 0 0 Slow
Also Blender works fine (surprise!). Could you clarify what kind of GL extensions / GL visuals / whatever Houdini is looking for? Just to check in case if I can upgrade a kernel / driver to make Houdini work.
And the last question - should
export HOUDINI_OGL_SOFTWARE=1
work in such case? Because for some reason it doesn't.
Thanks.
Houdini on Intel GMA
3258 3 0- hoknamahn
- 398 posts
- Pagefan
- 519 posts
Just some random thoughts Hoknamahn but your server runs glx version 1.2 and your videocard 1.4…
Did you install the intel-dri package?
Is the glx or dri module loaded in X?
On my quadro fx1100 i got 88 GLX visuals instead of just 3 in your setup…
And how can you say that blender runs fine????
Hope any of this might give you a hint…
Hans
Hans
- hoknamahn
- 398 posts
In the third line of glxinfo “Computer says yeeeeeessss”
And X.org log says exactly the same.
If I run Blender and it works without slowdowns and any glitches I could say “it works fine”. Actually not only Blender but also other simple OpenGL applications too (for instance Chromium without DRI slow as hell even on more powerful systems, but in my case it's fast).
What is suspicious to me in those 3 GLX visuals - all of them doesn't support accumulator. :?
f = conserve . diffuse . advect . add
fx td @ the mill
fx td @ the mill
- Pagefan
- 519 posts
