Im trying to do a cloth emitter ( like small papers in the street ). I tried using POP's but when i apply the cloth sim only the first cloth ( i used a copy node to create planes in every particle ) is simulated and the others dont appear. Then i tried generating cloth objects using the creation frame with the expression if($F<400,if($F%10==0,$F,0),0) to emit every 10 frames a piece of cloth and the same…the first cloth is generated ok, but when the second is generated in this case the cloth solver throws an error ( cannot retrieve data from previous solve ). I think that is something wrong with the geometry that the cloth solver process…I attached the scene file, any ideas why this happends?
Thanks!!!
Cloth emitter
5886 4 1- nzabala
- 66 posts
- michiel
- 428 posts
- nzabala
- 66 posts
- kirillfx
- steifi
- 4 posts
I'm getting the same error as kirillfx. My Houdini-Version is: 11.0.581
Does anybody know how i can emit cloth-objects without getting this error?
ERROR: Integration failed due to numerical problems
Edit: It works when i turn off “Make Objects Mutual Affectors” in the cloth solver. Anyway it would be cool to make it work with this feature turned on… any ideas?
