houdini master has stopped working!!!
   7168   3   1
I been using houdini for about a week now and then, sad to say it suddenly stopped working. The info below are the details that come up on the error screen. Can anyone help?
Problem signature:
Problem Event Name: BEX
Application Name: hmaster.exe
Application Version: 9.1.0.179
Application Timestamp: 47d6194d
Fault Module Name: USER32.dll
Fault Module Version: 6.0.6000.16438
Fault Module Timestamp: 45d3dc0e
Exception Offset: 00067715
Exception Code: c0000409
Exception Data: 00000000
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Additional Information 1: e369
Additional Information 2: 4a2d25a1511dca93f5cc9dc39d24e240
Additional Information 3: 9e7d
Additional Information 4: c5dca5e29ca3eaacaa0a3ea186119af6
People like you and I, though mortal of course like everyone else, do not grow old no matter how long we live… never cease to stand like curious children before the great mystery into which we were born.
-Albert Einstein,
Hi there,
Welcome to the forum. Are you still unable to run Houdini? Can you post more information about your OS and hardware? Can you run other programs like the License Administrator and Image Viewer, for example? Did you perform any updates to your machine prior to the issue?
Cheers!
steven
Here is the error I recieved…
The LIBUI.DLL file is linked to missing export KERNEL32.DLLGetConsoleWindow.
C\Program Files\Side Effects Software\Houdini 9.1.179\bin\hmaster.exe
A device attached to the system is not functioning.
Which version of Windows are you running? 9.1 is fairly old and probably guarenteed to not work on Windows Vista. I would suggest trying out the latest Houdini 9.5 daily build. Even then, I don't think Houdini will run on Vista 32-bit unless you turn off UAC.
