Pre render scrips
   2999   2   1
hi
i did a scene in houdini were i have the low poly and the hi poly geometry linked to the same switch node.
and i want it the switch node to switch to the second geometry(the hi-poly one) only at render time…
does any one know how i can doit?????
i saw the “opparm” exprection but i dono if it is the exprection and were i can use it …..
cheers
There is no need for a switch.
Simply set the render flag (purple circle) to your hi-res geo, and leave the display flag (blue circle) on your lo-res geo.
G
Like keyframe said, you shouldn't need a switch. However, if you do need it, you can do the following:
opparm /obj/objName/switchSop input 1
Alternatively, you can also use Takes without the need for scripting.
Cheers!
steven
