I am a Houdini apprentice. From the houdini help, i know when using the “mouse” node, there should be a “record” node after that. I think “keyboard” node is the same way to use. But it does not work.
What should i do?
Thx.
How to use the keyboard in CHOP?
2903 2 1- Rye
- 2 posts
- edward
- 7714 posts
I'm not sure where the menu item for it went but the hotkey to enter “Intercept Mode” (as mentioned in the Keyboard CHOP helpcard), is the Scroll Lock key. Once you hit it, you enter intercept mode (the frame number should disappear). Now you should be able to see the Keyboard CHOP react to the specified keypresses.
- Rye
- 2 posts
edward
It works! Thank you very much.
