I have a ball which is traveling a lot. And at the same time it has to emit fire and smoke. To keep the ball always inside the volume container, I have to increase its size a lot, and thus reduces the resolution. Can I have animated Volume Container, which travels along with the ball.
I am animating the container, but its position doesn't update in dynamics.
Animated Volume Container
3193 2 1- iamjaideep80
- 82 posts
- circusmonkey
- 2624 posts
- cb
- 635 posts
circusmonkey
Shelf > Volume Fluids > Resize fluid
should be what your looking for
r
Either that or a slightly higher-level tool on the same shelf:
Burn from Object
This tool creates two containers for the object from which you want to emit fire and smoke: an animated/resizable one for fire and a larger, static one for smoke. Dive into the auto-created DOP network to find out how it works.
