Hi All ,
Yes another Vops question !.
I created a toggle called “Do offset” when checked on it allows the user to add an extra set of data from the vop called rint3 , to the existing node “basic frame offset” via an if then block.
If “do offset is checked on ” rint 1 and rint 2 should be added together then piped out to the attribute node “ start offset ”
If “do offset” is not checked on , rint should just pass through on its own to the attribute node “start offset ”.
Does this seem correct ?
The other part of my question refers to the vop , boxed in green. It peels off the BBZ value. Is there a way to set it up so a user can peel off either X , Y or Z . As currently a user would have to dive inside the otl and manually change this value.
r
Vops If then Block
5618 3 2- circusmonkey
- 2624 posts
- keyframe
- 1529 posts
Regarding your first question, sounds like a switch vop would do the trick (instead of the if-then block).
Regarding your second question, I would imagine that a drop down menu with the options listed for the user to select from a set of options – which I believe puts in your vex code land, and the joys of the #pragma statement.
G
G
- tamte
- 8449 posts
no need for VEX land for this
you can use switch VOP for both your questions
drop Switch VOP
create new int parameter for it's switcher input
check provide menu of choices on it
and fill it with this string: 0 “X” 1 “Y” 2 “Z”
connect x, y, z to switch node
connect switch to your clamp node
the same way you can bypass if/then block
just compute values for both cases
connect them to switch VOP
and use your dooffset as a switcher
drop Switch VOP
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- circusmonkey
- 2624 posts
