Is there any tutorial or information on how to transfer a attribute created in SOP's with “Attribute Create” to a shader?
Because obviously Im doing something very wrong And cant really find the info im looking for.
/M
Attribute's and Shaders ?
4142 8 2- MagnusL3D
- 1104 posts
- jason_iversen
- 12450 posts
Make an attribute (usually a Point attrib, but others will work) with the same name as the shader parameter. Eg. “rough” will override Roughness on the VEX Metal SHOP.
- keyframe
- 1529 posts
It's actually a lot simpler then is sounds.
If you create a float point attribute called “neener” on your geo, all you need to do is create a float attribute called “neener” on your shading network, and they will bind correctly. You RMB on an input, and select “Create Parameter”.
Watch your signatures though – float, vectors, etc…
G
G
- MagnusL3D
- 1104 posts
- keyframe
- 1529 posts
- MagnusL3D
- 1104 posts
- Allegro
- 696 posts
http://www.sidefx.com/index.php?option=com_content&task=view&id=1500&Itemid=132 [sidefx.com]
I'm pretty sure there was an example of this in video 12 if not earlier in the series.
Stephen Tucker
VFXTD
VFXTD
- MagnusL3D
- 1104 posts
- MagnusL3D
- 1104 posts
