Stamp technique in the Copy SOP
5882 5 3- SergVideo
- 50 posts
- silvina
- 181 posts
Look at the docs online:
http://www.sidefx.com/docs/houdini10.0/nodes/sop/copy [sidefx.com]
At the bottom, there is a series of examples that use copy stamp.
That should be a good start :wink:
- Jenny
- 121 posts
- SergVideo
- 50 posts
Thank you!
I completed tutorial “Copy the star onto the sphere”. Then I added Transform node between Sphere1 and Copy1 nodes. I want to rotate the sphere with the stars. When I rotate sphere by “rotate” parameters of new Transform (xform2) node, stars rotates too around its local axis. What is the problem?
- old_school
- 2540 posts
- SergVideo
- 50 posts
Jeff!
It doesn't work. When I changing “Rotate” parameter in the Primitive SOP, sphere deforms. I attempted to delete pivot channel in Primitive SOP. After this sphere stops to distort, but stars still rotates. I don't understand why! Tell me please, why when I making transformation with sphere, some stars don't inherit this transformation (rotation)?
