Hello there.
I was trying to to setup our network to take advantage of the “mantra -H”, but im getting an error message. Baically I have 2 machines (woody and buzz, woody is the localhost), im logged into both as an administrator. The two machines are finding each other fine. When I use
mantra -H “woody,buzz” - I get the right result. To test whether buzz is doing its job i type
mantra -H “buzz” - Thats when I get a message that tells me something like “the string/pipe conection is broken” and nothing happens
If I type mantra -H “woody” it works fine.
are there any special network settings that need to be specified? buzz is already running hserver.
Im using win2K
Thanks a lot for your help
Rudy
Network Rendering setup
3727 3 1- rcortes
- 33 posts
- davedjohnson
- 221 posts
Two thoughts:
1) You don't need the quotes around the hostnames. I don't know if this is causing your problem, but you don't need them.
2) You need to have hserver running and healthy on buzz and woody. On buzz, type hserver -l at the command line to see if it is working. If it is then you have a different problem. If not, type hserver by itself to start the hserver.
Dave
Dave
- rcortes
- 33 posts
- davedjohnson
- 221 posts
