Hi guys, I'm totally lost here I downloaded the apprentices version of Houdini and tried to run it but the server will not allow me a license nore will it accept a manually generated one comes back with an error on line 3 and line 5 totally lost here what can I do? I'm regestered and all and as I mentioned I did the web page attempt to generate the 5 lines of code.
Please help
can't seem to get a license Help :(
4047 4 1- Master Raven
- 3 posts
- goldfarb
- 3455 posts
- Master Raven
- 3 posts
well the app will still not load but the server seems to be active now????
anyway here is the info…
Diagnostic Output:
If you are having licensing problems, please save this information and email it
to support@sidefx.com.
License Administrator output:
Generated on: Mon Sep 22 22:29:38 2003
Local host name: RICHARD
Local server code: fe84d70d
Local ip address: 127.0.0.1
License server name: richard
License server server code: fe84d70d
Server ip address: 127.0.0.1
License server is running: Yes
Has SERVER license: Yes
License server version: 6.1.128
May modify server from this machine: Yes
License Administrator version: 6.1.128
Http proxy host: (none)
Using standalone mode: Yes
Can retrieve http://license.sidefx.com/index.php: [license.sidefx.com] Yes
Installed licenses:
LicID Platform Product Ver Avail Expiry
sesictrl -i output:
—– SERVER richard ——–
hserver -l output:
Hostname: RICHARD
Uptime: 2 days, 8:05:29
License Server: richard
Server Version: sesinetd6.1.128
Version: Houdini6.1.128
ReadAccess: +.+.+.*
WriteAccess: +.+.+.*
107 of 255 Mb available
CPU Usage: 2% load
0 active tasks (1 slots)
licenses file:
## Side Effects Software License File
# For license information, please contact:
# Side Effects Software Inc.
# 477 Richmond St. West, Suite 1001
# Toronto, Ontario, Canada
# M5V 3E7
# licensemanager@sidefx.com
# http://www.sidefx.com [sidefx.com]
# NOTE: This file may be modified by the licensee
# Key installed 21:55:08 09/22/03
SERVER richard fe84d70d e50e96097fe31b0f25fe84c1f3af50a96a4440c1396e51
Diagnostic Output:
Installed licenses:
sesictrl -i output:
hserver -l output:
Hostname: RICHARD
ReadAccess: +.+.+.*
CPU Usage: 2% load
licenses file:
# M5V 3E7
- Master Raven
- 3 posts
- tallkien
- 225 posts
