I am running the free appentice version on my Lifebook (Fujitsu) 5010 tablet. I have a modified open gl video card. When I open Houdini I get this message:
Warning: OpenGL shader extensions not available.
This is a limitation of your video card
or driver, and will prevent Houdini from
using GLSL shaders.
Set the HOUDINI_OGL_ENABLE_SHADERS
environment variable to zero to avoid
attempts to use this extension.
How do I do this? Thanks for any help.
How do I set OGL shaders to zero?
9190 5 2- michaelws
- 3 posts
- heydabop
- 203 posts
- drew
- 117 posts
See
http://en.wikipedia.org/wiki/Environment_variables [en.wikipedia.org]
Specifically the bit that says “The most common method of setting an environment variable in Windows is via <Control Panelystem:Advanced:Environment Variables>”.
Edited by - Oct. 28, 2009 19:47:30
- michaelws
- 3 posts
Not being a programmer, I noticed in the .env file there was a “#” at the beginning of every sentence.
I did not use the # when I entered “HOUDINI_OGL_ENABLE_SHADERS = 0” not the quotes. Was this the correct way to enter it?
Sorry to sound like such a novice.
Never used Houdini before…I have owned 3ds Max since version 1,including 2010…but wanted to give Houdini a try.
Thanks for the help…and any further instructions if I got it wrong.
- heydabop
- 203 posts
- michaelws
- 3 posts
