This:
http://www.freelance-animation.com/newwebpage/tutorials/uvmapping.html [freelance-animation.com]
is a really interesting way to create a UV map. Basically the author copies the chunk of geometry he wants to UV, then uses the modeling tools stretch/flatten it out, then makes a planar UV map, and then transfers that back to the original. Is this possible in Houdini? I can envision branching off of the last node, adding a bunch of edit SOPs to modify the geometry and then add a UVTexture node to get a UV map. However would this still be in effect for the main branch of the network? Is there another way?
Article on creating UV's
4689 6 2-
- jimc
- 295 posts
- probbins
- 1145 posts
Use the UVPelt tool and you'll be able to do the same thing but without mucking up the geometry. Using the various uv editing tools you have great control over how the uv's are managed.
“everything is coincident”
- jimc
- 295 posts
- tamte
- 9372 posts
jimc
This:
it is perfectly possible, even if you need to cusp some edges when modeling the flat version of your object and thus changing the point count
here is simple example file with 2 examples using the same method
1. with the same point count
2. changed point count due to edge cusp
- probbins
- 1145 posts
Yes, the uvpelt tool is definitely for organic shapes.
This first two videos in this series should help explain the uvpelt functionality;
http://www.sidefx.com/index.php?option=com_content&task=view&id=996&Itemid=132 [sidefx.com]
- pelos
- 624 posts
http://www.menithings.com/main.php?action=how&how_id=7&manual=1 [menithings.com]
they way you mention was to set up a morph in a plane idea to use it as planar projection. but you needed to manually do it.
today with the new technology, modo at least my knowledge was the first on presenting a UV unwrap in the version 201 (i think, dont remeber well). that was latter adopted by Max and Maya, finally XSI with the 7.5 version. i cant tell for Houdini for how long it has it.
but with that, you don't really need to do it use that technique any more.
just UVpelt, control a polygon inside the pach you want to UV, and thats it.
- edward
- 8078 posts
pelos
I, on the other hand, can tell you how long Houdini has had it.
r44210 | xxxxxxx | 2003-07-21 20:29:08 -0400 (Mon, 21 Jul 2003) |
Draft implementation of the Pelt SOP.
