I was playing around with my airframe model, and trying out the UV features in Modo and comparing them to Houdini. In Modo they have a UV tool called UV Unpack, which, from what I can tell, is roughly the same as Houdini's UVPelt. However in Modo the tool seems to do a better job of keeping the basic shape of the geometry when it unwraps it.
When you use the UVPelt tool, at least with rectangular/boxy geometry, it seems to want to round out the edges as the vertices are stretched out and come a little closer to the circular frame. Is there a way to keep the edges straighter? The documentation mentions a “Stiffness Attribute” and a “Weight Attribute”, is that what these are for? The sidefx tutorial doesn't mention these and haven't found an example about this either.
UVpelting question
3583 5 2- jimc
- 295 posts
- probbins
- 1145 posts
- jimc
- 295 posts
Yeah I tried that too. However UVUnwrap sop doesn't pay any attention to which edges you'd like the geometry to break at, like the UVPelt sop does. Sometimes it works OK, other times it breaks the geometry into too many pieces and there's doesn't seem to be the finesse like there is with the UV Pelt tool - it'd be nice if there were something inbetween or the UVUnwrap could be altered to accept edges like the UVPelt does.
- Simon
- 2199 posts
You probably mean something like this
http://www.houdinitools.com/HT_HDK_UVunwrapLSCM.html [houdinitools.com]
unfortunately I've been rather tardy about recompiling for H10… ops:
- jimc
- 295 posts
I'm a C++ developer myself (http://vcf-online.org/ [vcf-online.org] is a project I used to work on quite a bit). How difficult is this to build on Windows? I have Visual Studio 2005 Standard, is that the correct version?
- Simon
- 2199 posts
