Hi all ,
I am currently hacking around with vop sops.Trying in vops to create a set up where the user can control where the emission of particles can occur on the surface of an object.
I have had some limited success with bounding box values but at any one time only in one axis. Ideally I would want to control where the particles emit in the x y and z axis. Almost like using a carve sop to define the area , with a fall off .
I have pretty much hit a brick wall with any idea how I could do this in vops except for the fact I could maybe use the point normal as a start point. Does anyone have any ideas ? . I have attached a scene ready to go with my imported area attribute and output attribute. Would be interested in any thoughts.
Rob
VopSop selection based problem
1980 2 0- circusmonkey
- 2624 posts
- probbins
- 1145 posts
Two ways that I would likely use,
In your curve example I would use Attribute transfer; colour the curve and use the colour value as a grouping value and the Attribute transfer is where you can control the fall-off.
The other way would be somewhat similar in that you use colour as a grouping value, but then use a Paint sop to paint the area that you wish identify.
You can override the colour value in the Paint sop and paint with any variable that you wish to create.
“everything is coincident”
- circusmonkey
- 2624 posts
