How to create points that represent objects in SOP?
just like the DopImport SOP node have an option called “create points represent objects.”
For example, the there are 4 objs in the attachment file,and how can I create points that have the same movement as the objs?
thanks
6226 3 1- laiwayne
- 58 posts
- probbins
- 1145 posts
In your example, put an Add sop below each of the “objects” and turn on “Delete Geometry But Keep Points”.
Just to clarify though, these are not Objects ( in Houdini ) they are Primitives inside a single Object.
“everything is coincident”
- laiwayne
- 58 posts
probbins
thank you. that does work, but what if I just want each single point to represent each Primitives, then how can I do it ? like 4 points represent 4 primitives
- midorime
- 31 posts
