yapofire
Oct. 25, 2003 09:45:24
I have found a tutorial at:
http://www.digitalproducer.com/pages/using_houdinis_particle_system.htm [
digitalproducer.com]
for creating simple grass in Houdini. The problem is I think it was written for an old version of Houdini. I am running version 6.0 and cant seem to work out how this tutorial can be related to the newer version. I have just started learning Houdini so I am sure the answer is probably simple.
Any help would be great
Thanks for your time
tallkien
Oct. 25, 2003 10:05:09
You should have no trouble working the same tutorial in houdini 6. A few things might be out of sync but not too much difference. A notable exception would be Materials. Older versions had Texture operators and Material Operators. Shading is now done in SHOPS with a little help from VOPS. Tiles looked a bit different but worked the same way
If you are getting stuck at any particular place in the tutorial, post your problem, folks here will be only too glad to help.
cheers
yapofire
Oct. 25, 2003 10:14:05
I am on part 4 and cant seem to set the birth object to my grid. Im assuming that in Houdini 6, source group is where i would do this? I have already set the SOP to be my grass object.
tallkien
Oct. 25, 2003 10:50:59
In the tutorial version, the Object and the sop (inside Object) were two seperate fields. In 6 you navigate directly to the sop. So you would pick /obj/Model/grid1 in the Source field
The source Group is used if you have a group sop appended to the grid and wanted to use a subset of points on the grid. In this case leave the source group field empty
