In pop network, I can no longer modify velocity or acceleration of particle after wire a position Pop.
is there any way to make it possible?
Is there any way to solve the big problem?
2891 3 1- flyingc
- 160 posts
- flyingc
- 160 posts
- probbins
- 1145 posts
I'm just guessing but it is likely you have static values in your Position pop, meaning that you deleted the $TX,$TY,$TZ expressions. The Position pop evaluates per frame, as do all pop's and in this case if you have a static value as a position that is what will be provided each frame.
This means any acceleration after the position will seem not to have an affect.
“everything is coincident”
- old_school
- 2540 posts
