I need to write a more complex expression for controling for example the tx of an object in this maner:
if ($FF==15) than
tx=bla, bla;
else
tx=2xbla;
endif
but I don't know where to put it. maybe there is a CHOPS op that let you write code inside.
another one will be:
can I use a parameter/attribute which I declared, like $BLA, with parameter/attribute in the above statement?
thx
how can I write complex expressions
5443 5 1- calin
- 114 posts
- craiglhoffman
- 252 posts
You put it right in the translate X channel. Just start typing in there.
You can do logic and anything else. You can keyframe animate from frame 1 to 10, then from 21 to 30 and put your expression on the curve between frames 10 and 21 using the Graph Editor if you want.
No crazy “Expression Editor” like in some other packages. You just put it where you want it.
Quick example: Try putting sin(10*$F) in the translate X channel. Your object will move back and forth.
Does that answer your question, or did you mean something else? Also open up the Textport and type “exhelp”. It will give you a listing of all expressions available to you. For more info on a particular expression type it again with the expression name: “exhelp sin”.
-Craig
-Craig
- edward
- 7714 posts
- deecue
- 412 posts
actually there is a crazy expression editor.
if you go to alias/variables (alt+A), there is an expression tab. you can make your expressions in there and give them names. then in your channel/parameter, you can just refer to that global expression by giving its name..
oh and craig is right, you can just type right in there as well.. just if it's a long one, you can just refer to it doign the above method in case you like that method.
hth,
dave
Dave Quirus
- calin
- 114 posts
- craiglhoffman
- 252 posts
