Hello there… Im having some problems with rmands. When i run it with
rmands -d dsomewhere -L myrmanshads.olt myshaders.slo
I get the right dialog.. the only problem is when I load the otl some of the parameters come in with a type I dont like… for instance most of my strings come up as a file type parameter . This is not terribly bad , but I would like to edit the dialog so that I can turn some of these strings into drop down choice menus, check boxes (for booleans) and things like that (I really like how I can do this for vex shaders). but when I edit the otl file it gets ruined… (houdini wont load it anymore)
I could also do the dialogs with *.ds, but the scripting documentation refers to what I believe is an older file strucutre used in 5.0, I cant find the files or folders they tell me to use to have houdini load my *.ds automatically.
Can someone please help.. Thanks
cheers
Rcortes
rmands dialog editing
3718 2 1- rcortes
- 33 posts
- Mario Marengo
- 941 posts
rcortesHmm… when you say you "edit the otl file", you mean litterally opening up the file and editing it with a text editor? If yes, then that explains why Houdini won't open it up. Despite appearances, these files have portions that are binary. I don't wnow all the details, but I can pretty much guarantee you that the header is (likely among other things) a binary “otl_section” table indexing into the rest of the file – i.e: change anything beyond this and all the offsets in the table become invalid :shock: … luckily, you don't need to hack the file – they give you tools to edit these things 8)
Once you've created your otl and loaded it into Houdini, make an instance of it in, say, “ /shop”, RMB on it and select “Type Properties” from the popup menu. This brings up a dialog that allows you to change just about everything in your Op, including adding/deleting/rearranging parameters, as well as changing the widget type assosiated with them (equiv of a #pragma hint in a VEX source file).
To hand-edit the actual dialog section of the OTL (assuming the above doesn't allow you to do what you want), select “Tools -> Operator Type Manager” from the main menu. In the Operators tab find your OP (likely under “Operator Type Libraries -> CurrentHipFile ->…”.
RMB on the entry for your OP_Type (Shop/myRmanShader) and select “Edit Contents…” from the popup. This brings up a dialog that you can use to edit each section of an OTL (well, the non-binary ones at least). And this is what you'd use if you wanted to muck about with Houdini's dialog-script syntax.
Hope that helps.
- rcortes
- 33 posts
