Hi everybody !
I have made an ocean with a grid and trying to texture it BUT when I apply the texture on (VOPsurface) the render of the ocean is white, why? I have modified the color thanks to a “ligthing model”, it should be blue.. .
Thanks for answering
how to apply a VOPsurface on an ocean?
5225 10 0- alwineberthe
- 14 posts
- alwineberthe
- 14 posts
- tamte
- 8535 posts
- alwineberthe
- 14 posts
- tamte
- 8535 posts
- alwineberthe
- 14 posts
- tamte
- 8535 posts
i meant if you can post here some example file showing your problem
or just describe your problem a little bit more, or some picture of your VOP network might help
it's difficult for us to imagine what might be wrong without some info of your setup. Therefore your file with a little description of what you want and what is wrong would be the best for us to help you. If you cannot share your file then any file with the same problem might help.
it still seems to me like some error in VOP surface SHOP. It can happen very easily
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- alwineberthe
- 14 posts
Sorry for the misunderstood ! Yes I understand it isnt easy to resolve the problem without seeing the whole scene. Well, not quite easy to explain or discribe, i don't have a very good english (technical words, etc) but I have hadded in attachment an exemple file showing my problem, it might be the solution
- tamte
- 8535 posts
your lights are at intensity of 10 which is just too much making everything white
you have 2 lights at this value
also keep in mind that turning off the display flag on the light object will not turn off the light for rendering
to do so you must uncheck Light Enabled parameter on the light
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- mawi
- 242 posts
- alwineberthe
- 14 posts
Thank you!!
The hight intensity was for a test and I forgotten to change the value after.. .
ops:
I've got an other question, I have a texture, a basic liquid found on the library, it work pretty well on the drops but the same texture applied on the ocean don't look the same (that's why I'm trying a VOPsurface), why? Moreover the waves don't appear on the render, why?
[img690.imageshack.us]
ops:
