cookie error
3416 2 0- oat
- 479 posts
Hi, I was trying to use the Cookie SOP to get a polygon which is cut out from polygon A by a polygon B with holes.
the cookie node works fine with one polygon but not with another one.
Can you help to take a look of the hip file and advise me what I've missed?
the 1st image shows the problematic cookie result.
the 2nd image shows the correct cookie result with different polygon input.
the hip files associated with both images are attached.
the digital asset file used in the hip file is also attached.
- tamte
- 8449 posts
- oat
- 479 posts
