I have some questions concerning the use of area lights for raytracing.
1. It seems that the area samples driving the light and shadow quality (raytraced shadows). Is there a way to decouple light samples and shadow samples?
2. Is there an easy solution to get the shadow a color tint rather to just control the shadow intensity?
questions about area light
4014 7 1- roughsporty
- 191 posts
- circusmonkey
- 2624 posts
- symek
- 1390 posts
- roughsporty
- 191 posts
- symek
- 1390 posts
roughsporty
So, how would I be setup this light with a custom shadow shader?SYmekroughsportyNot other then custom shadow shader.
by adding “shop_shadowpath” parameter to this light. This allows you yo apply your shader to a light.
- mawi
- 242 posts
- roughsporty
- 191 posts
If I understand it correctly I have to go inside my surface shader of my object which cast the shadow?
But that would mean if I have 2 area lights and one surface shader I only have the control for “one” shadow.
Can you give me an example?
mawi
In the surface shader you can “cheat” it by testing isshadowray() and set Of to be 1-yourShadowColor if true.
- symek
- 1390 posts
