Disabling compilation optimization
   2256   1   1
I heard somewhere that there is a compiler option to stop the VEX compiler making shortcuts. Thinking I'd never use it………
Heres the bit of code im using:
sop
linegroup(){
int test;
int group;
string groupname;
test = import(“line”, group, 0, ptnum);
groupname = sprintf(“group%d”, group);
newgroup(groupname);
the compiler only runs the sprintf command once though. When I use printf instead to check if its working, it does! I'm guessing this works for printf as a special case for debugging??
Can anyone help me out?
Henster
Henster
I have not found the compiler options I mentioned but I got the code below working. So for anyone thats doesn't already know ( most probably myself when I forget in a couple of days! )
sop
linegroup(numofgroups){
int test;
int i;
int group;
string groupname;
for(i=0;i<=numofgroups;i++){
if(group==i){
or something like that. It seems to think it can get away with the sprintf otherwise.
Henster
Henster
