please !
I dont want to give up I`m eat a lot of dirt with Houdini creating cloth\wire simulations ….
some one can help me get this one to work !
wire around stick ...
4383 5 1- James_Burg
- 153 posts
- Jenny
- 121 posts
- James_Burg
- 153 posts
- Jenny
- 121 posts
Here is your example with the static stick.
You need to join your 2 lines into 1, and then make it a wire object. Try and use the shelf tools as much as you can to set up your DOPs sim. If your wire is passing through the stick you will need to increase the substeps on the AutoDopNetwork node.
Side Effects Technical Support
- Jenny
- 121 posts
- James_Burg
- 153 posts
