Hi
I do some lessons from 3dbuzz and have following problem
I get new geo,go in SOP and have box and grid created
and now I want to assign 2 different material to those object
I can't but if I create 2 different geo's in OBJ box and grid then I can ,at this stage I have to have in SOP those two object together
Best regards,
Ben
Assigning materials/shaders in SOP possible or not?
5568 9 1- Ben Lumumba
- 58 posts
- stevenong
- 1631 posts
Hey Ben,
There are two ways to do what you want:
a. Append a Shader SOP to each Box & Grid SOP, assign the shader with each Shader SOP & merge the geometry.
b. Append a Group SOP to each Box & Grid SOP, assign unique or identifying names to each, for example “box” & “grid”, merge the geometry then append a Shader SOP. In the Shader SOP, under the Primary Shaders tab, click on the “More” button to add one more set of parameters, set the first Group parameter to “box” & select the shader you want. Do the same for the “grid” group with the second set of parameters.
The above assumes you're using Houdini 6.0 & above. If you're using 5.5, there are already a few set of parameters available in the Shader SOP which performs exactly the same as I described above.
Cheers!
steven
Cheers!
steven
- RobertP
- 48 posts
- RobertP
- 48 posts
- RobertP
- 48 posts
- RobertP
- 48 posts
- RobertP
- 48 posts
- tallkien
- 225 posts
- stevenong
- 1631 posts
- RobertP
- 48 posts
