Hi all,
I was wondering if there´s any method of creating a lookat constraint for a camere, that keeps the camera levelled when orbiting around the target, like for example in …. any other 3d software?
I couldn´t find it in the manual or here in the forums.
Any help appreciated.
Camera and Lookat
16492 13 1- OneBigTree
- 378 posts
- goldfarb
- 3455 posts
- OneBigTree
- 378 posts
Hi Michael,
I mean, creating a targeted camera it is usually done with a lookat constraint with an upvector that keeps the cameras X-axis always parallel to the horizon. In Houdini however I can´t seem to get this working with the lookat parameter. Even if “use up vector” is on and orientation is set to 0,1,0, the camera rolls when I move it horizontally and it is not on Y=0. It´s the same behavior when I try to orient the cam with the orientation manipulators, and it´s very inconvenient. Am I missing something?
- goldfarb
- 3455 posts
- OneBigTree
- 378 posts
- goldfarb
- 3455 posts
well there might just be something buggy going on…which happens in free software also…
on looking a bit deeper…
there IS something buggy here:
Houdini 11.0.504
create a null at the origin
add a camera
set the look at of the camera to be the null
using the parameter pane - move the camera around - the camera looks at the null and maintains it's orientation
using the move tool - the camera looks at the null, does not maintains it's orientation, the rotation parameters pop to new values each time you touch the jack
using the pose tool - the look at parameter gets blanked out!
very strange…I'll send something to support about it….
Houdini 11.0.504
add a camera
- OneBigTree
- 378 posts
Hi arctor, I´m using build .547
It indeed shows the behavior you described, except all my rotation values stay at 0 although the camera rolls when moved by the handle. Weird.
I wonder why there´s no other thread in the forums about this, I mean the camera is the most fundamental component of a scene after all.
Anyway, thanks for your support!
I´ll just ignore the camera for now.
- goldfarb
- 3455 posts
got this from support today:
Hi Michael,
I suppose you are using the camera handles to try to position your camera, rather than the move tool.
Camera Orientation Handles and Look Up objects can't be used simultaneously, this is because the Camera Orientation
Handle will move the look-at or eye point itself, in other words, it won't be looking at a null anymore…Actually if you notice,
the look-at path also gets cleared out if you are using the Orientation Hanlde
If you switch to translate and rotate handles (on the left side of the viewport) it should work fine.
Also, you can RMB on the camera handle and choose focus or frustum handles, these should also work.
As for the pose tool, if I select Object-specific handles, it will give me the Orientation Handles and we will fall in the above problem.
If I select Global Transform Handles, then it gives me translate an rotate handles, and it works fine…
Let me know if I am missing your point…
Silvina
Hi Michael,
Silvina
- OneBigTree
- 378 posts
- silvina
- 181 posts
- OneBigTree
- 378 posts
- old_school
- 2540 posts
And as wolfwood said locking the rotate parameters gives you what you want in the meantime.
One aside, I kind of like the rotates in there when your camera is animated linearly along an object. Pretty cool. What I don't like is that the rotates can change whenever you touch the handle. Not good.
- OneBigTree
- 378 posts
- rmagee
- 1170 posts
Does this file do what you want. It has a camera parented to a null object that is “looking at” another null. It also has the camera set as unselectable so you don't get the strange handle issue when using the handle tool. Now you can select and move the two null objects and there is no strange rotations.
